Good old, What do you think it will run?
#41
A glide might be in the future if the car doesn't run like I want, but I kinda wanna keep it streetable. I know it is 100% race car, but still does have tags and can be driven to the track.
#42
If a good shop built the 80 you'll be fine. It's just a tank of a transmission. It's the same gearing as a th400, just has an overdrive planetary on the front half of it. Is your trans a center lube or front lube?
#44
Are the trans cooler lines above one another in the front of the trans, like a normal 4l60e? Or is one in the middle of the case, and one in the front?
If it's in an Fbody I'm sure it's a front lube.
#45
I had the same setup in my ss, built 4l80 and locked my converter up in second gear and never once had an issue with it, I also ran 4:10 gears with a 30 inch tall dr. only difference was mine was a 402 with a hydrolic roller
#48
on 250 worth I went 9.22 at 148 with a 1.28 60 ft. on 450 worth of gas i went 5.6 at 127 in the 1/8 but never ran the car out the back door, 5.6's should be good for 8.6's or 8.70's i would think, the car was heavy though, if i recall 3,500 with me in it.
here is that 9.2 pass
#49
#50
Ok, I am getting very close to coming home and running my car. Running 250 out of the hole and 200 on the second stage, what plugs do you think I should be running, 10's? Also, do you think c16 will be good? Thank you.
#52
And the heads to go with the short block.
![](http://i1210.photobucket.com/albums/cc402/josh1engine/Sherwood_230a.jpg)
![](http://i1210.photobucket.com/albums/cc402/josh1engine/Sherwood_230.jpg)
AFR 230 heads with 64cc combustion chambers, 2.08 intake and 1.60 exhaust hollow stem valves.
PAC 1207 springs
Comp solid roller lifters
Yella Terra 10mm solid roller rocker arms
Manton pushrods
PAC 1207 springs
Manton pushrods
