HSW Microedge Interface Settings Please Help
Old Jun 8, 2012 | 06:18 AM
1BaddLS2's Avatar
Default HSW Microedge Interface Settings Please Help
Trying to get the Standard Interface to fire my noids and use it as a simple window switch but it pulses them rapidly and then it shuts them down in between the window range.
Can someone with experience please give me a walkthrough on setting it up. Have asked Harris Speedworks via Trouble ticket and at first they were helpful but are not answering my questions.
At this point I have already performed a reset of the Inteface and set it to default
Isolated/Checked my grounds, fuses etc.and also my relays and they are functioning fine. Also I need to add my solenoids work perfectly with a microswitch so they are already isolated.
My car is an LS2 TBSS
Tps Signal = 4V off of purple wire at the throttle body
Tach Signal = injector wire
Thanks In Advance
Old Jun 8, 2012 | 01:46 PM
1BaddLS2's Avatar
Anyone have an idea
Old Jun 8, 2012 | 02:07 PM
Skinny's Avatar
There's your problem. An injector wire can't give an accurate tach reading. Use a coil wire or the tach output from the PCM.
Old Jun 8, 2012 | 07:42 PM
1BaddLS2's Avatar
Good guess man ! But CRAP i ran it from the PCM and the same rapid fire clicking
