Pressure Sensor Off Feed Line or Bottle?
I'm thinking that off the side of the bottle makes a lot of sense so that I know if my pressure is high enough before opening the bottle, but then I'd have a lot of stuff hanging off the side of the bottle. It would basically look like this but with one more pressure sensor for the gauge on that side manifold (picture borrowed from a post by Beer99C5)
I already have a small analog gauges on the bottle and was going to mount my pressure switch off the valve side port as well so I don't have to worry about over heating.
I prefer to know exactly whats in the bottle before I open it, and that way if theres a problem, I can crack the valve and let some pressure out first
because my bottle heaters are controlled by my Holley EFI Dominator
IF I turn on my heater, by accident or on purpose, and I have forgotten to open the valve, I wont accidentally overheat the bottle because the sensor is on the bottle side before the Valve.
other guys like the sensor on the line so they know when their bottle is really opened or closed...
not saying it wont survive up there, but you are more likely to have one just quit or read wrong because of the constant vibration up front...totally dependent on how its mounted of course.
then you can get a 1/8 npt TEE fitting and use that as you still should have a pressure gauge on the bottle for a quick visual reference for anytime tha gauge is not active(like when filling the bottle or when the car is shut off just for some examples...
any 1/8 NPT brass fitting from Home Depot/Lowes/Hardware store of your choice will do the job...
