Just spray for the first time.. delay when activated???
hey guys i just sprayed for the first time with a 50 jet for both fuel and n20. when i activate it past 3500ish there is a slight pause then pulls perfect no detonation. its the stock tune with no timing pulled and tr6 plugs(switching to bf7s soon which i know someone will comment on that) any thoughts?? too much fuel?
this is just me I'm not the best but ur playing a dangerous game with just a stock tune and no timing Idk how bad it is with a 50 shot I'm using a 100 shot and had my timing backed down three degrees personally I would limit the times u.spray until u get a tune the delay could be air in the lines do u have a purge?
Posted from LS1Tech.com App for Android
the only different between mine and ur set up is my shot is bigger and I'm using a single nozel wet kit and dyno tune.. this is all on a 01 z28 stock rwhp before dyno 258 after dyno 330 then spray 440 just some numbers for u u running a plate kit with a good tune I can pull a little more than 50 out of ur shot also ur fuel air ratio needs to be tuned or u will run to lean sorry this is so long just letting u know what I know
the only different between mine and ur set up is my shot is bigger and I'm using a <a class="inlineAdmedialink" href="#">single</a> nozel wet kit and dyno tune.. this is all on a 01 z28 stock rwhp before dyno 258 after dyno 330 then spray 440 just some numbers for u u running a plate kit with a good tune I can pull a little more than 50 out of ur shot also ur fuel air ratio needs to be tuned or u will run to lean sorry this is so long just letting u know what I know
highly recommend a purge if u don't have one I'm looking at stall converters so I can spray off the line I hear a 50 shot is awesome to use to get moving u might look into a converter for some great launches plus if ur willing to spend the money a nano kit is well worth it
Idk what vehicle u have but if u ever go bigger than a 50 u might have to change fuel pumps I had to but this also gave me room to run what I plan on upgrading to witch will be a duel stage 50 then to a 150
I can't say.wether u will be fine or not I'm just sayings what all I did to protect my motor since its my only transportation
oh sorry, no purge kit right now.. was thinking that as well being the issue. i have the summit dual window switch, i looked for a lot of help and couldnt get the damn signal from that to complete the circuit.I pulled that out and just wired it directly to the relay. i do have WOT switch from nitrous outlet. im selling the summit switch because i was so frustrated with it. I am hitting the arm switch when it reaches 3500 plus(6k red line) feel a slight delay.. then boom it sprays perfect through 1st.. second then let off..same happened with 2nd and third run.. Dave are you out there?? lol so i was guessing my fuel jet maybe too much?? i have no idea ugh
Idk what vehicle u have but if u ever go bigger than a 50 u might have to change fuel <a class="inlineAdmedialink" href="#">pumps</a> I had to but this also gave me room to run what I plan on upgrading to witch will be a duel stage 50 then to a 150
it very well could be as simple as just needing a purge I'm also use the wot switch from Nitrous outlet work just a arming toggle switch I like it better than a control module just cause its there when I want it not when a computer thinks I want it also I notices delays of the same type when my purge gave out got it fix now no issues
it <a class="inlineAdmedialink" href="#">very</a> well could be as simple as just needing a purge I'm also use the wot switch from Nitrous outlet work just a arming toggle switch I like it better than a control module just cause its there when I want it not when a <a class="inlineAdmedialink" href="#">computer</a> thinks I want it also I notices delays of the same type when my purge gave out got it fix now no issues
I'd like to see perfect plugs with a 50n and 50f jet no offense, please don't take that personally. I just hear it a lot. Hell I can't get a perfect plug either as I don't think they exist! We as humans always want more!
I would pull at least 4*-5* pop the BR7's in, get a wideband or at least confirm the afr on a dyno with a wideband before spraying again. Good luck.
Oh and a purge!
Oh and a purge!
