A few install questions...
Old Jun 27, 2012 | 11:45 AM
Wicked69's Avatar
Default A few install questions...
Here is a picture of my set up. Stock 5.3 twin Turbo. I am running -10 fuel line up to a "Y" fitting and then -8 to the rails. My kit is an older Nitrous Express Plate kit. It is already been drilled for E85 use. I was going to run the plate between the intake and the tall elbow. My question is what is the best way to run the fuel to the plate? The fittings on the plate for both nitrous and fuel are very small. I figured I could just run a "T" fitting where I have been running my fuel pressure guage. So one could go to the plate and one for the pressure guage. Is there any reason i couldn't do this? I am only going to run a 50 or 75 shot to help with spooling the turbo's.
Here is a close up of the regulator. You can see the brass plug. I now run a line from that spot to my fuel pressure guage on my cowl hood as in the above picture. That is the spot I was going to put in a "T" fitting.
