BR7s Gap
Old Jul 3, 2012 | 04:53 PM
Canada204's Avatar
Default BR7s Gap
What should i gap my plugs to?
Old Jul 3, 2012 | 11:31 PM
Fbodyjunkie06's Avatar
How much spray, and compression?
Old Jul 4, 2012 | 08:36 AM
Canada204's Avatar
Stock compression and be spraying 150 175
Old Jul 4, 2012 | 08:41 AM
Carter01's Avatar
I would say around .036 would be fine.
Old Jul 4, 2012 | 07:24 PM
^This.
I think they come close to that out of the box. I'd just run them out of the box if it were mine, but double checking isn't a bad idea.
Old Jul 4, 2012 | 08:23 PM
Justins00ss's Avatar
Listen to these guys. I run mine a touch tighter at 32 to 34 but out of the box should be just fine
Old Jul 4, 2012 | 10:30 PM
camscam02's Avatar
br7 out of the box is .025 for everyone I've touched
Old Jul 4, 2012 | 11:44 PM
You thinking that's too tight?
Admittedly I run mine out the box.
Old Jul 5, 2012 | 08:10 AM
Canada204's Avatar
So the bigger the shot the mnore compression the bigger gap you run how big can you run the br7s?
Old Jul 5, 2012 | 09:58 AM
Dynospeed's Avatar
No the larger the shot the tighter the gap you will run.
Old Jul 5, 2012 | 10:29 AM
Correct.
More CR, more nitrous, tighter gap. Same with boost.
I have never checked the plug gap on a BR7EF as I only used them twice before I stepped up to the B8EFS plugs and I check their gap out of the box sometimes(hardly ever check plug gap and I should) and it's usually .026 but I figured(assumed) BR7's would have a looser gap out of the box than a B8EFS would.
