N20 with procharger
How does one cope, correct or properly install a WET type system, I'm looking at a direct port system (per injector). If the current fuel system is on a Return post rail setup with a 1:1 boost regulator.
So, as boost increases, so does the fuel rail pressure. Clearly, will not work while n20/fuel is on as the fuel will increase based on the boost.
What options are there to make this work?
The car is SD, so there is no dry type option.
Trey
