MSD Window Switch Question
Old Apr 23, 2002 | 04:54 PM
horist's Avatar
Default MSD Window Switch Question
OK, when the car is below the desired activate RPM (in my case below 3000RPM) and I connect a volt meter to the output (yellow) wire, and the other end of the volt meter (positive) to a 12v positive power source from the car... should it read 0volts or will there be a reading? I guess i'm not understanding how the MSD Window Switch works
Old Apr 24, 2002 | 11:01 AM
slow's Avatar
Default Re: MSD Window Switch Question
it should read 0 volts when not in range
When you are in the desired range it should register 12-14V most likely closer to 14.
Ryan.
Old Apr 24, 2002 | 02:49 PM
horist's Avatar
ok, maybe I have it hooked up to the wrong wire?
it's on the #10 wire which is white on my pcm (the lower pcm that's more towards the front of the car)
2000 A4 TA
