Will one 255L inline pump kit be good ??
Old Apr 24, 2002 | 07:26 PM
BIGBOS's Avatar
Default Will one 255L inline pump kit be good ??
This kit includes the pump, mounting brackets, and all fittings, it operates at a higher pressure than the normal ones...says they have gone 10's at 123 with it, would it be safe if I sprayed a 150 wet on this??
And would a intake or out of tank be better, what are the advantages, the in-take is cheaper... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
The in tank one is $139 and the out of tank one is $169...
Should I get one?
<small>[ May 03, 2002, 07:46 AM: Message edited by: BIGBOS ]</small>
Old Apr 25, 2002 | 08:24 AM
BIGBOS's Avatar
Default Re: Will one 255L inline pump kit be good ??
TTT
Old Apr 25, 2002 | 10:23 AM
Slowhawk's Avatar
LS1Tech Sponsor
You should be good to go.Just make sure you run a bigger power wire.10 gauge or even 8 gauge for a little overkill.The stock is a 16gauge <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
Old May 3, 2002 | 07:45 AM
BIGBOS's Avatar
I am getting the in-line one, will that still be ok??
Its still the 255L one
Old May 6, 2002 | 09:37 AM
MN_Z28's Avatar
I ran a NOS in-line (not in the tank) and it couldn't keep up with my 150, 100, OR 75 TNT wet setup.
Personally, I'm convinced you need a in-tank for the TNT wet...
Old May 6, 2002 | 01:20 PM
383LQ4SS's Avatar
If you put a 255 lph inline with the stock pump it will not flow 255 lph, Probably no where near. An intank 255lph is always better than a 255lph inline after the stock pump.
Old May 6, 2002 | 02:18 PM
DaveH's Avatar
I would also recommend getting the in-tank pump. I got 602rwhp out of a single walbro 255l hp pump. I'd get the gss-341.
Old May 6, 2002 | 04:12 PM
Ls1 382ci SS's Avatar
I have the Walbro 255in-line fuel pump which I got from Speed inc. Now with the 382 coming in and the 200-250 shot with the 37 lb injectors I will most likely be upgrading to the sumped gastank from speed inc with a 420inline fuel pump.
I hope this setup does well.
talk to Tom Bos and I am sure he will help you out on this.
Old May 6, 2002 | 04:35 PM
BIGBOS's Avatar
Yea I did a while ago and he said it would be fine, the inline is a lot cheaper to install too, because with the in-tank you have to drop the rear, etc...I also e-mailed TNT asking if I could put the inline on, they said it would be fine, I plan to make around 535rwhp and probably somewhere close to 700lbs of TQ with the 150 wets on there...I will also monitor the fuel all the time and the AFR's etc... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Thanks for the suggestions.. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old May 6, 2002 | 07:41 PM
Postal's Avatar
You can never go wrong by overbuilding your fuel system. I'd say just go with the dual 255 LPH intank pumps by ARE. You just may end up with H/C soon enough. Then you'll need a fuel upgrade possibly again
I'm going all out with mine. ARE 422, TNT 250 wet. Going with Speed fuel rails, external regulator, billet filter, Aeromotive Eliminator fuel pump and a sumped sheetmetal gas tank from SpeedInc.
Old May 6, 2002 | 07:50 PM
BIGBOS's Avatar
I probably won't do heads for a WHILE...do you think the inline kit will be safe for now?
Old May 7, 2002 | 12:13 AM
love2xlr8's Avatar
I would go with the set-up ARE has out if I were planning on anymore 150 shot excusions into insanity <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old May 7, 2002 | 07:45 AM
BIGBOS's Avatar
TTT, need a few more opinions on this.. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old May 7, 2002 | 11:08 AM
BlackhawkSS's Avatar
im curious too. i will be running a 150 dry shot.
so far i only have 30 svo injectors, but i want to get an inline and not a intank fuel pump. i have cam and dont plan on heads anytime soon.
the inline fuel pump im looking at is an ACCEL 500 hp inline pump. i should be safe right? mods are on my site
Jerry
