how does this combo sound
Old Aug 1, 2012 | 03:51 PM
Cam99's Avatar
Default how does this combo sound
Going to the track tomorrow to see the results, but what do you think of this combo. 99 SS auto. Nitro daves wet kit pilled for 150 shot. widow switch spraying 3500-5900 rpm. 3 degrees timing pulled during the spray window. A/F is 11.9 while spraying and BR7 plugs gapped at 32. The other mods are lid, slp maf, lt's, 3" ORY, hooker catback, and rear girdle. Anything I'm missing?
Old Aug 1, 2012 | 04:00 PM
Neal@NitrousOutlet's Avatar
Sounds good. You might want to do a run on some new plugs and see where you timing mark is on those plugs. You might need a little more timing pulled but it all would depend on the setup. Everything looks good just thought i would throw the recommendation about checking the timing.
