Running rich. Will MAF ends lean me out w/N20?
I am running so rich that when I spray I get a gray smoke. Will ported MAF ends lean me out just enough to get rid of the smoke? I dont have autotap and I am on a limited budget. Do you think it would be risky?
Wes
Wes
Re: Running rich. Will MAF ends lean me out w/N20?
MAF ends 9 times out of ten will lean you out some. How much may be different from car to car. So it may help, but how much is not certain. Why not take the $99 that the MAF ends cost and put it towards a MAF translator. Youll be able to set it wherever you want to. It will help out on NA performance as well if your as rich as you say you are. Just try to get to a dyno with a wideband O2 sensor to set it up. Thats relly the only way. And you should do it after any major change. Thats just the cost of being safe.
