Anyone with Heads/cam N2O please enter..
I have even thought of putting 150hp n jet in and just using larger than 150 fuel jet??? PLEASE HELP!!!! I WAS OUTRUN BY A SUPRA THIS PAST WEEKEND!!
You should be able to run that 150 shot as long as you have enough fuel, have at least TR-6 or colder plug gapped tight (.030-.035), probably have to retard timing a few degrees, maybe add some race gas too. Basically...I believe you either went lean and/or were experiancing detonation. Go through your entire setup again and go overboard on fuel requirements and conservative on timing, plug gap, etc.
Do you know what your kind of timing you are seeing on your car at WOT?
we have no widband around here so me and a few supra guys may pitch in a nd buy one ourselves.
im running 28* max, gapped at .035
i did not use spray when beat by the supra.
