dry nitrous set-up question
Old May 7, 2002 | 09:25 PM
yellowls1truck's Avatar
Default dry nitrous set-up question
hey, im new here nad hope you guys could give me some info. i was wondering if it matters if you mount the nozzle before or after the maf sensor? i know the maf take reading of the incomming air, but wouldnt the o2 sensors also adjust for the a/f raito also?
Old May 7, 2002 | 09:57 PM
horist's Avatar
Default Re: dry nitrous set-up question
w/a dry kit you are relying on your MAF to adjust the fuel... I'm pretty sure it has to be pre-maf.
It would be very bad if you sprayed after the maf, engine went way lean... and kaboom!
Old May 8, 2002 | 11:14 AM
toeffer's Avatar
Install for dry system is always before the MAF. The O2 sensors will pick it up only after the damage is done...after the nitrous has gone past the pistons. Fast SS on NOS is an expert, Email him. Or check the colonels N2O tech files.
<small>[ May 08, 2002, 11:15 AM: Message edited by: toeffer ]</small>
