Test hits Carb'ed 408
I totally forgot about that in Ultra Street.
That said, I'd try a slightly higher air pressure around 17psi.
If it likes that try cranking a click of compression(tighter) if you have double adjustable shocks in the rear.
These two things have always worked for me to alleviate tire shake with a 275 radial.
Ive only had 3 test days on this engine combo, and Im pretty sure there is a good amount left in it
They are $$$, but you high rollers got the dough!
#35
i just picked one up off a customer... i cant wait to try it next year...
#37
No you just need the right solid roller
#39
Damn for some reason I must have you confused with someone else. I thought you had a carb'd IS single stage fogger on there, but once again I forgot about the Ultra Street rules about not being able to use a fogger. Well put a .082 jet in that beeotch and let it ride!
Ive got an IS fogger on a LS1 SuperVictor....sitting on the shelf.
an 0.082 jet is less than a 200 hit on the plate I have, Im about to throw some .108's in it and let it eat.
#40
I have a mut kit. It is a Edlebrock RPM performer kit with a zex black out perimeter plate in favor of the spray bar plate and a nos mini controller. And the nano bottle to reg the psi.
I have only spray it about a dozen times and it feel great on a .058 jet. Now I am taking it to .062. We are taking it to LS Fest with this setup.
You guys going?
You guys going?
