112 leaded Splash with small dry shot
good luck
Forget the race fuel thing. You can spray more than that on pump fuel with a timing tuner like the one from Lingenfelter.
I should just had asked if 112 would be any different than 109 other then eating o2's and plugs, performance wise that is.
No race gas would be needed for such small shot, but then again it helps with timing and give some safety cushion till I can get a proper tune, I only have experience with 109 unleaded which I had used in the past on previous kb/sprayed car, thus why my main concern on trying 112 leaded now and reason I made the thread...
How much timing does the car run NA? What are the AFR #'s on spray?
If you dont want to spray the car correctly and tune it right, no gas is going to give you a safety net.
It seems that you are just looking for someone to validate your experimentation with this tiny dry shot of N2O. I have also done things that the masses on the interweb 99% disagree with. I have used a couple gallons of leaded race gas in the tank of my 2001 Z06 (approx 9 gallons of 91 octane pump gas in the tank prior) while at the drag strip (1/8 mile) and I was warned by a more experienced racer and tuner (AFTER having purchased and poured the leaded fuel into my car's tank) that it would destroy my oxygen sensors. I raced the car on the fuel and drove it home and haven't seen any O2 sensor issues. This was about 3 years ago and I still have the same O2 sensors on the car, no issues.
Now theres a local selling a diablo intune, I was thinking scooping that and use it to retard timing or send the pcm to frost so he can adjust the timing for the jug. Does anyone knows if Frost can burn a chip
or w/e so I can keep my n/a tune and have a diff tune for nitrous? what would you do, intune or frost?
