Bone Stock..Spray It?
So... 98 Z28 M6... TR6s and a Walbro being the only mods... what can or should I spray at this thing, and what could it run?
**Ive had 5 of these so I do know the cars and the weak links, im just new to Nitrous and thinking i;ll have some fun seeing what I can push this car to run with basically no mods**
I'd spray it!
Had a buddy that had an ls1 goat that sprayed it. His car was bonestock, only thing he did was pull timing. he put a 150 shot on it.
OP,are u doing wet or dry?
What's the better route? My car is stone stock also.
Im VERY split on the wet vs dry thing. I have read endless threads on this and from what i see there are some very fast cars running both set-ups. I am leaning toward wet simply because by the time i buy injectors to support a bigger shot I would probably be near the cost of a decent wet set-up to start with.
So say 4* on a 150 would be pretty safe? 4* from stock of course...
Im open to any and all advise including wet vs dry (if we can keep it from walking off a cliff LOL)
Id say expect Atleast a half second to a second quicker then u are now.
I know with my lt1 formula,which was an a4,with out n2o it ran 13.3,on a 150hp shot,it went 11.60,175hp it went 11.40 but the stock 10blt hated it.
It's all in the tune up. Run a NGK BR7EF plug gapped @ .025 and pull 2 degrees for every 50hp of spray on pump gas. You can get away with more timing if you're running good fuel.
Also, this is VERY important. Make sure your rear steam ports ARE NOT blocked off. Alot of guys end up butting up the top compression ring on #7 and even #5 if they're blocked off.
With that being said, 150hp on a LS1 will last a long time if a few things are done right.
