Fuel supply question
Old Sep 1, 2012 | 06:55 PM
MFJ's Avatar
MFJ
Exclamation Fuel supply question
I have a NX Proton Plus nozzle kit and I'm going to spray 75-100 shot. The instructions say cut the fuel line and insert the "T" fitting to supply fuel to the noid. I'm not to happy with "cut the fuel line".
Can't I just use one of the fuel ports?
Old Sep 2, 2012 | 02:00 PM
MFJ's Avatar
MFJ
Nobody?
Old Sep 2, 2012 | 02:45 PM
rpcase's Avatar
Tap off the fuel rail test port.....remove the schrader first. Im on my cell so i cant see what type of car you have, but this is the normal way of doing it.
Old Sep 2, 2012 | 03:17 PM
MFJ's Avatar
MFJ
Its a trans am. That's what I thought just wanted to make sure. Thanks for the reply.
Old Sep 2, 2012 | 03:28 PM
My6speedZ's Avatar
Yes just tap the rail, its common and easy.
Old Sep 4, 2012 | 10:34 AM
Neal@NitrousOutlet's Avatar
Pull the valve out or get a fuel line adapter. no need to cut your fuel line.
Old Sep 4, 2012 | 11:47 AM
MFJ's Avatar
MFJ
Thanks for the replies. Thought it would be kinda strange to cut my fuel line. (Wasn't gonna happen)
Old Sep 4, 2012 | 11:49 AM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
Yeah on our Proton is a universal system and that is why it comes with the tee but in your case you can just grab it off of the test port as mentioned above.
Trey
Old Sep 4, 2012 | 12:14 PM
MFJ's Avatar
MFJ
Trey
Yeah that's what I figured just wanted to make sure.
