Holy seeping solenoids, Batman!
So, wet kit went on fine, sprays fine, solenoids/relay click on/off fine, but there's a problem. When the fuel system has pressure and the N2O system is off, we leak fuel out the nozzle. With the kit apart and the nozzle in my hand, i can see it drip. Anyone have any idea's? Has this happened to you?????
Ryan
-2001 GMC 2500HD, 6.0L, HPP3, NX.
<small>[ May 22, 2002, 03:14 PM: Message edited by: Ryan ]</small>
Ryan
If you don't want to hassle sending it back, you can disassemble the solenoid and try to clean it. It comes apart pretty easily. There may just be a tiny piece of trash stuck inside it. Just be careful about what kind of solvent you use inside the solenoid. Heck, a blast of compressed air may do just the trick by itself.
Or, you could just have NX send you a replacement...
thanks for the response george. when i get home tonight or tomorrow ill see how hard it is to tear down without the wrench. i wonder if they'd mind me driving the 2 1/2 hours to their HQ and asking them there <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
ditto on what george said...undo the nut at the top, pull the magnet switch off, then unscrew the base. I'm betting a piece of dirt/teflon got in the seal...clean it off and you should be good to go <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
I had my nitrous solenoid leaking slowly out the the coil side of the valve. I put some aircraft grade sealant around the gap to see if that helps. All it did was bleed out the gas when I felt the bottle open.
NX has a lifetime warranty on all there solenoids. I would just send it back and they will get you a new one.
<small>[ May 26, 2002, 03:45 PM: Message edited by: Bad Habit Bird ]</small>
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Bad Habit Bird:
<strong>NX has a lifetime warranty on all there solenoids. I would just send it back and they will get you a new one.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">no ****? <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" /> j/k
i didnt (and still dont) want to wait that long. no biggie
