Spray and Pump Vs. Racing Gas
Ls1tech & Truck Sponsor
Me personally I have sprayed 250hp on 93 octane but i did pull a lot of timing out to do it so it was a dog with out it. If you are planning on driving it everyday or just occasionally I wouldn't run more than 150.
I have upgraded to a S.A.F.E. tank now and it runs much better not having to pull near as much timing.
Trey
Trey
not to hijack but what do yall think about a 500rwhp car on stock lines and rails with a 200 wet shot. would running a S.A.F.E. tank with race fuel allow me to keep maximum timing while on the jug and off without having to replace lines and rails?
If you're well up to date on reading plugs and you're dedicated to truly reading your plugs the right way then this could work for you while spraying that much.
If you're one of the types that feels like it's not needed(reading plugs that is) then I wouldn't attempt what Minytrker said.
