Way lean while spraying
Intake only 02 z06
Hsw plate
Nx stage 6 lightning solenoids
Nx window switch
Lnc2000
Tr6 plugs
3000psi nano kit
.046 .028 jets
Aem wb02
Equal length lines from solenoids to plate
I've been working on the kit and the wiring for the last week or two. Took it out last night to test it out.
When the kit comes on at 4k Afr jumps up to 14.5-14.7. Got out of it the first time. Tried it again thinking it was just a lean spike and after about 1.5 seconds it starts breaking up I think. It kinda sounds like a rev limiter.
Upped the jet to .031 same thing happens. Then again on a .035.
Does this soynd like a specific problem to anyone. I didn't get much into diagnosing it last night. I'm wondering if I have a clogged fuel line to the plate or maybe fuel solenoid not opening.
Any other suggestions
Thanks
You should probably make sure that your fuel solenoid is opening up.
Also look at some non projected tip plugs like the BR7.
You may also want to double check wiring and set up parameters on the lnc2000.
Neal, I talked to someone at nano and was told 47 28 was a good placf to start. I believe it was you earlier this week. Not sure why now you are dating atleast 31f
Bottled closed and system on the afr pegs at 10.0. So the fuel side is working.
I have went over wiring and checked the lnc again.
Changed to a 50 shot
31/18 and the car ran good. A little leaner on the afr then I liked. High 12s, no breaking up.
75ish shot
38/24 ran great Afr was high 11s low 12s
85-90?
41/26 no breaking up, but high 13s afr
How do I calculate what shot im doing, from the nitrous jet or the fuel jet? With the nano my nitrous jet is smaller then the standard size.
I want a 100 shot, so I'm thinking a 28f and 44n
75ish shot
85-90?
You calculate your shot by the Nitrous Jet. Everyone is different as far as what jet = what horsepower on their different items. If it was our plate it would have been a 52N/31F for a 100 shot.
With the Nano you should have a larger jet not a smaller jet in the fuel.
I told nano that what I looked up for a 100 shot is 52/28, they told me to drop the nitrpus jet down to a 46 and keep the 28.
So for nano you would suggest a 52/34 for a 100 shot.
I was not decreasing the fuel jet size. I was decreasing the nitrpus side. Or adding to the fuel side.
Luckily my friend had a selection of about 10-15 jets. But it still sucks to have to guess because nano cant give me an accurate recommendation. So I'll have to buy more and more jets.
Thanks for your help
