Safe total timing 50-100 shot?
Engine is a 5.3L with a 218/222 113.5 cam Pat G cam, TFS 205cc heads, 10.8CR, LS6 intake, shorty headers, 3.00" exhaust and CAI. I was tuned last summer for N/A.
I ordered the NX proton kit with their Gen-X accessory kit, LNC-2000 timing controller, and NGK-3177 plugs gapped at .035"
My timing at WOT is 26* with 10.8:1 CR. Should I start off with dropping 4* with a 50 shot?
Opinions needed please
I am searching right now! Last edited by DavidGXP; Dec 31, 2012 at 10:46 AM.
Just because your buddy has been spraying with no timing pulled that this guy should do the same. His combo is probably totally different than this guy and that calls for tuning it to that specific combo.
There are different ways to tune also. DavidGXP here can pull 6or even 8* and lean the **** out of it and run just as fast or faster. Making power by creeping up on the timing is not always a good thing. Many guys have burned stuff up like that.
I agree with king-lt1. Pull 6 and hit it with the 100 then check the plugs
^^^Exactly. Even with your AFR at 12-12.2 some big boys like running it leaner.
I plan on using a 50 shot with 2 degrees pulled, and use my dashhawk to monitor spark knock. I do not have a A/F gauge, so I will have to pull plugs.
My plugs look light brown, with a tint of white right now
My main question for this thread; is if 26* of total timing, is to much for a 50 shot with 2* pulled (24*). I have seen some LS people talk about using 19* total!
I am just worried because I am not stock anymore, so maybe pulling more timing would be smart.
This car stock had 31* Crazy.....
