Need info from a LS nitrous guru
Old Oct 22, 2012 | 03:38 PM
RUSS_RACING's Avatar
Default Need info from a LS nitrous guru
What gap is best for a 10 heat range NGK plug shooting 300???
__________________________________________________ __
1991 S10 2800lbs
LQ4 Iron Block - 0.30 Over
Stock Crank
Eagle H-Beam Rods
Ross Racing Pistons
12:8 to 1 Compression
Comp Cam - Hydralic Roller .646/.646
Dart Pro1 Heads
Victor Jr Intake
Pro Systems 1000cfm Carb
NOS Big Shot Plate System Set Up For 300 Shot
Hedman Husler Longtube Headers
Powerglide Transmission
5000 Stall
Moser 12 Bolt Rearend 4.10 Gears
275/60/15 M/T Drag Radial
Old Oct 22, 2012 | 05:20 PM
WhiteLTone's Avatar
i run my 10's gapped at .025. - 12:1 comp on c116 spraying 200-250
Old Oct 22, 2012 | 06:55 PM
I was thinking .022....I'm new to the LS world and not sure if that is too small of a gap or not.
Old Oct 23, 2012 | 11:30 AM
StrokerTA's Avatar
We have run it as low as .016 in WhiteLTone's car, generally I like them from .020-.025..
Old Oct 23, 2012 | 01:19 PM
Sales@Tick's Avatar
I'd start out where Stroker and WhiteLtone run theirs around .022-.024.
LS coils have a pretty hot spark for what they are and can tolerate a tight gap.
Old Oct 23, 2012 | 01:27 PM
StrokerTA's Avatar
Remember, bigger gap on the spark plug does *NOT* equal a hotter or stronger spark. All you are doing is spreading out the spark thus making it weaker, especially when adding added cylinder pressure to the mix.
Just food for thought.
Old Oct 23, 2012 | 02:03 PM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
As Martin said I would star around the .022-.025 range.
Trey
