Which nitrous system to use
Old Oct 27, 2012 | 09:40 AM
mustangwalker's Avatar
Default Which nitrous system to use
I have a 40k mile 2000 model stock ls1 c5 corevette and I would like to add a about a 150 to 200 shot of gas to play around at the track some. Which would be better for me a wet or dry system and name the brands and part numbers please PS MY CAR HAS A VORTEX AIR BOX ON IT. 1'M NOT NEW TO NITROUS BUT NEW TO THIS LS1 STUFF
Here is my GM POWER NITROUS MUSTANG....
Old Oct 27, 2012 | 09:50 AM
rpcase's Avatar
I prefer a wet setup, but they are more expensive than a dry.With the wet setup you should he ok up to a 150 shot but after that youll need to upgrade your fuel pump. If you go dry you will need to buy bigger injectors no matter what.
I prefer nitrous outlet stuff....great quality and customer service. NXis another good brand as well.
Old Oct 27, 2012 | 10:02 AM
Thanks alot and thats the info I was needing.
Old Oct 27, 2012 | 11:25 AM
rpcase's Avatar
No problem....you will also need a way to pull some timing with anything above a 100 shot.
Old Oct 28, 2012 | 08:22 AM
vbls's Avatar
Nitrous Outlet kit is the way to go, i have ALL the kits over the years, and theres hands down is great. Customer service is on point. like they said above, 150 wet, fuel pump, and tune. you will be ready to go
Old Oct 28, 2012 | 09:02 AM
Sales1@Texas-speed's Avatar
^Agreed give the guys at Nitrous Outlet a call! They make an excellent product, and offer great tech support if you ever need it!
