Adjusting ignition timing on MSD optispark?
Old Nov 1, 2012 | 10:47 PM
04rev600's Avatar
Default Adjusting ignition timing on MSD optispark?
Is this possible? i have heard you can adjust +/- 5 degrees by the flat head screw, but then some say there is no possible way to adjust timing. i want to run a little nitrous but dont want to spray without adjusting timing.
Thanks
Old Nov 2, 2012 | 04:05 PM
Chopstix's Avatar
Dont do it...just not accurate enough to be used for nitrous IMO
your sig shows you have the 6AL...MSD makes an add-on module to add timing retard to that unit
http://www.summitracing.com/parts/msd-8680
think thats the one
Old Nov 6, 2012 | 12:10 PM
04rev600's Avatar
does this retard timing? From what i can see it only adv timing?
Old Nov 6, 2012 | 12:12 PM
04rev600's Avatar
nvrm yes is does reatrd timing. thanks for the help! does this just plug into the 6AL?
Old Nov 7, 2012 | 02:10 PM
Chopstix's Avatar
yes it will install with your existing 6al per the instructions that come with the unit
