I found it!!!
Old Jul 2, 2002 | 10:09 PM
rich's Avatar
Default I found it!!!
with the motor apart I found the #6 pistons to be a little warm but no signs of the knock /tick I heard and went away when I cancelled the spark to #6. I found the #6 exhaust valve to have deposits on the face and in the seat and the valve wouldn't seat and the noise was the combustion leaking into the exhaust and echoing in the header.A leak down test would have found it but the compression test showed a 10 psi diference and I thought it pinch a ring or cracked a piston. The deposits are parts of the burnt spark plug. <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
