Nitrous 408 LS2 Build Thread
Old Nov 24, 2012 | 08:41 PM
QucikSilver's Avatar
Default Nitrous 408 LS2 Build Thread
I've already started this so I'll try to document as much of the process that I have already done as possible.
To start:
Kotzur Racing LS2 408
Eagle Crank & Rods.
Arias nitrous pistons
Kotzur Racing L92 heads
24x/25x 6xx/6xx cam
Victor Jr L92 intake
6061 elbow
NW 102 TB
Nitrous Outlet Direct Port Rail System with Dedicated Fuel System & Nano
Th-400 with T-Brake 4400 ATI 8"
SMJ Line Lock and ABS Delete
LNC-002 two step & timing retard
Mosier 12 bolt 4:30 spool
QA1 frnt / rear
TRZ Adj LCA with TRZ Relocation Brackets
BMR Tube K
Madman Manual Rack
Wolfe Cage
Im sure there are a lot of things that I left out and I will add them as I remember. I should preface this as saying that this car started out as a 2000 Trans Am WS-6. I am converting it to a formula and repainting it and completly re-doing the interior in the process.
I will post pictures as I get them uploaded.
Attached Thumbnails Nitrous 408 LS2 Build Thread-1315369314658.jpg   Nitrous 408 LS2 Build Thread-1318312357576.jpg   Nitrous 408 LS2 Build Thread-1318996200199.jpg   Nitrous 408 LS2 Build Thread-1318996218816.jpg   Nitrous 408 LS2 Build Thread-1319000538856.jpg
Nitrous 408 LS2 Build Thread-img_20111021_134514.jpg   Nitrous 408 LS2 Build Thread-1321556805087.jpg   Nitrous 408 LS2 Build Thread-1321556805924.jpg   Nitrous 408 LS2 Build Thread-1321556806371.jpg   Nitrous 408 LS2 Build Thread-img_20120621_203521.jpg
Old Nov 24, 2012 | 08:51 PM
Couple more pictures....
Attached Thumbnails Nitrous 408 LS2 Build Thread-img_20121104_151733.jpg   Nitrous 408 LS2 Build Thread-img_20121104_151742.jpg   Nitrous 408 LS2 Build Thread-img_20121104_151827.jpg   Nitrous 408 LS2 Build Thread-img_20121104_151856.jpg   Nitrous 408 LS2 Build Thread-img_20121124_162539.jpg
Old Nov 25, 2012 | 10:18 AM
Firehawk441's Avatar
I recommend NOT using an 8" converter with a Nitrous engine.
Old Nov 25, 2012 | 11:02 AM
xpndbl3's Avatar
Buddy has been 8.83 on a 8" nitrous converter from PTC
Old Nov 25, 2012 | 11:17 AM
In a stock chassis/suspension 4th gen?
What raceweight?
Old Nov 25, 2012 | 03:23 PM
around 3300 with driver.
Old Nov 25, 2012 | 03:27 PM
When i had the converter spec'd I told them I was going to be hitting that converter with a 250-300 single stage. ATI told me it would do just fine. I also had it built when the car had less HP and weighed more, so it should be just a tad tighter as well.
Old Nov 25, 2012 | 08:23 PM
xpndbl3's Avatar
What raceweight?
3350 and ya a torque arm setup. Big cube sbc with fogger.
Old Nov 30, 2012 | 06:20 PM
hymey's Avatar
Have you contemplated more cam? what is your compression and fuel choice? the 240s/250s stuff is very torquey in the strokers , I like to run more lift and duration with them, late 250s intake early mid 260s exhuast, .700 lift, if you want to rev them up a bit. The LSA requirement really depends on what your static compression is, to a degree. The reason you need wider lsa in the plastic intakes is more to do with the average airspeed through the runner. I would port the victor junior run more taper and keep the LSA on 108-110 even though it is a nitrous specific engine. I have run 106 with those intakes on 6L and they pick up.
Old Dec 1, 2012 | 10:36 AM
I thought about stepping up the cam before the build somewhere around high 250's/ high 260's Mid 600'/600's on 110-111. But I didn't want to push the limits of a LS2 block twisting it to almost 8k on a 300+shot. So i decided to keep it around 7400-7500 on a 250 shot. This should be plenty to get me into the mid 9's. My C/R is 11.6:1. I still want to run pump gas N/A and C16 or Q16 in the Dedicated Fuel System for nitrous.
Old Dec 1, 2012 | 10:56 AM
I am also still debating which throttle body setup to go with. 6061 elbow with NW102 or accufab 4150 and build an elbow.
Old Dec 3, 2012 | 07:27 PM
BSmiff's Avatar
I would hope even at full weight you run much quicker than mid 9s with that compression and 250 off the brake.
Old Dec 3, 2012 | 08:12 PM
I'm just assuing around mid 9's from seeing what other guys setups are doing. If it goes faster than that, great. But I would be happy with 9.50's - 9.40's.
