My Fuel Solenoid Failed
FoFo
'96 Corvette GS "Clone" 454 / 400 N2O
<strong>I had a similar incident happen on the 150 shot but luckily i noticed the O2's drop to ZERO!!! I had a swelled solenoid seal on the plunger. Call TNT they will fix you up. This is caused by cheap gas which uses a ethanol additive to up the octane. NEVER buy CITGO gas. I always stay with Texaco and Chvevron after this incident and have never had a problem again. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">EXACTLY my friend. Thats what happend to mine, but I was spraying a 200 wet shot for a bottle and a half and NO engine damage. knock on some serious wood!!!
I now use only Amoco gas and now 0 problems. Citgo caused mine also. <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" />
<strong>umm, why wouldnt you connect the FPSS at the opposite end of the fuel noid? If it fails then it shuts down. makes sence to me, but i always see it before at the rail.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Most people have both solenoids tied to the same relay. The FPSS would complete the ground for that relay. Therefore, if the FPSS is on the other side of the solenoid, the ground would never be completed for that relay because there is no fuel pressure until the solenoid is open. You could do something like what you are talking aout if the fuel and N2O solenoids are on different relays, and the fuel relay does not have the FPSS completion but the N2O does. Then the fuel solenoid has to open and pressurize the FPSS before the N2O opens. I've thought about doing that myself, but I figured it was too much work and I wasn't even sure how much "lag" there would be. Safest thing to do is probably wire two fuel solenoids in parallel.
Remember fuel is just like any other thing in life you get what you pay for. I would also avoid Diamond Shamrock.
<small>[ July 09, 2002, 10:04 PM: Message edited by: cantdrv65 ]</small>
<strong>2 fuel soleniods in parallel? You wouldn't know one was bad til both were bad. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Well, I test my solenoids periodically, so I'm sure I would notice a problem. But yes, it is possible for two solenoids to go bad, not very likely though.
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by rich:
<strong>2 fuel soleniods in parallel? You wouldn't know one was bad til both were bad. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Well, I test my solenoids periodically, so I'm sure I would notice a problem. But yes, it is possible for two solenoids to go bad, not very likely though.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">If you wire two fuel solenoids in parallel and get bad gas, you will simply have two bad fuel solenoids instead of one..... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> Basically you've done nothing except add expense and labor. Think about it. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
<small>[ July 12, 2002, 12:04 AM: Message edited by: cantdrv65 ]</small>
<strong>If you wire two fuel solenoids in parallel and get bad gas, you will simply have two bad fuel solenoids instead of one..... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> Basically you've done nothing except add expense and labor. Think about it. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">If you add gas with ethanol, yes, you may be screwed. I don't think that they will both go bad at the same time, but it can happen. Most likely they won't both go bad at the same time though. The parallel fuel solenoids is a preventive measure for solenoids sticking closed for whatever reason, ethanol and other crap. I didn't say that parallel fuel solenoids was the answer to all your problems. If you don't check them routinely and put bad gas in, then skip putting two fuel solenoids in.
<strong>Ok, I get the "parallel" thing but if they both opened, wouldnt you get twice the amount of fuel you need? I first thought you meant in series like you run N2O noids sometimes to make sure you get the N2O closed off in case one sticks open but then I reread it. You're saying to put them side by side with a Y fitting before them and another Y before they enter the nozzle right?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">The jet that is at the nozzle is what controls the amount of fuel that goes into the motor not the amount of solenoids pushing fuel to the jets.
gauge on an 11 sec pass??? especially with an M6.
That is why I am going to shoot a dry shot, however
I never had any problem with my Nitrous Works wet
kit that was on our 96 M6.
With other applications, I have had NOS solenoids
go bad, but never gas ones.
I always run Exxon 93... as a side note.
Goodluck, I still think a good Fuel pressure safety
switch would be a good idea????
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by cantdrv65:
<strong>If you wire two fuel solenoids in parallel and get bad gas, you will simply have two bad fuel solenoids instead of one..... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> Basically you've done nothing except add expense and labor. Think about it. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">If you add gas with ethanol, yes, you may be screwed. I don't think that they will both go bad at the same time, but it can happen. Most likely they won't both go bad at the same time though. The parallel fuel solenoids is a preventive measure for solenoids sticking closed for whatever reason, ethanol and other crap. I didn't say that parallel fuel solenoids was the answer to all your problems. If you don't check them routinely and put bad gas in, then skip putting two fuel solenoids in.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Simply install an A/F gauge...It is cheaper and you will see the lean condition immediately. You get some bad fuel and both solenoids WILL swell shut thus you have spent more funds and prevented nothing.
