Whats the most you can spray and be safe with a nitro daves 2 stage plate
I have a 102mm nitro daves 2 stage plate. I ran 4 passes in the 9.9's this past friday on a 200 shot . I was wondering who is spraying a 300 shot or more threw there plate? I know that anything over 250 should go direct port but this plate was built and flowed to support a 400 shot with a 6AN feed line to it.I just want to know if anyone is doing it. I was running C16 in my stand alone and run C12 in the tank and I'm running a #8 plug. I think I can get away with a #7 if I leave it as is but was thinking about spraying another 100 or 75 threw it so maybe I just leave it as is
I have ran 150 in each stage (300 total) and 200 in each (400 total) on pretty much every plate Nitrous Outlet sells. Just start with low timing and read your plugs. Also make sure every thing can support that amount of nitrous. I always run 6an main feed line cut to length and run all Nitrous Outlet high flow lines and fittings (Y's vs T's etc..). I personally like to run either a 15lb or (2) 10lb bottles on 300 or more especially if your running 1/4 mile.
