228r prc 5.3 stage 2.5 + 100shot
Yeah i think your getting on the convertor to hard. I launch between 1,500-1,800 rpm and i have pulled 1.61 on motor with the way my car is setup in my sig. As far as hitting the rev limiter it sounds like you need to get it tuned. My car also did that because the mph/rpm for the shift wasn't right. Once i got that fixed it works great. Should be alot faster once you tune the trans and launch at a lower rpm.
i hope to get my car out this weekend the one we have been talking about has been my brothers. i might start off with a 150 and go from there.
241 ported polished my self, ms3, 150 hit, 500lb lighter than stock.
I run a 5000 stall in mine, flashes to 5500 on nitrous. Now unfortunately I don't have any great numbers to post for you as I've done nothing but launch it from idle..lol I havnt had much time at all to tune the suspension. But do no let large stalls turn you away, I was on the phone with FTI for about an hour discussing the converter for my car. Every car seems to like something different, my suggestion would be to call a few converter companies and see what route they suggest.
My bro lsxtalemy posted for my setup 228r and 5.3s after some tranny running got it to shift threw the gears
Ran the car Friday night the only change was converter and a/c delete the car finally hooked ran a 1.6 60ft 7.1 at 95 on muscle and 1.5 60ft 6.70 at 103 car still spun a bit lifted the tires about 7inchs vids on drag racing results if you guys want to see
n55 is what we are using i thought that was a 100 thats what my homeboy told me it was, and 32f if im not mistaken
full weight car. ac, power steering. only things taken off is front bumper support and sway bar. the gear is a 373 and a yank 3600 that suck's **** the car doesn't stall passed 2500 rpm.
Yes I was running .55 jet gotta dobble check the fuel but think its .32 and it has a racetronix pump with the hot wire kit how much of an in improvement would I see switching out the jet to a .28
Definitely get the tune for the trans fixed. My camaro is bolt ons with 3.73's and stock converter running a 100 dry shot and i do 7.3@96 on DR's. You are definitely leaving alot on the table.
jblankenship is right ur fuel jet is a little on the rich side... to be honest check with who makes ur kit and see what they recommend as far as what u should start out with... from there make a hit pull then plugs and see how they look adjust fuel jet and timing from there... there are a few threads on reading plugs correctly on here.. check them out if it helps u any.. they will give u a good idea of what u need to look for.. ill be honest u will not get the tune up spot on in 1 day.. atleast i never could it took me a couple trips to the track to were i got it some what good BUT NOT PERFECT.. this isnt something i like to try and make big changes.. make small changes and take ur time
Just checked my jets it was actually n.055 and f .035 this is with a nos system with the shark nose oh and it has the big shot solenoids so I mite be running really rich the. Huh?
