Another MAF/Dry shot question
The thing is to autotap your motor and record your AFR/Timing at WOT as a base line. 75 shot dry is like 63 hp wet. small shot by any standard.
I still have stock tune and i shoot with NO JETS. Around 125-140rwhp. No knock or other issues.
A big help is NGK TR6 gapped at 0.040 and gas here is 98 octane.
Do not run platinum plugs (N2O doesn't like that). TR6 are one step colder plugs.
Obviously you are starting small (good thing), so you can increase the shot as you go.
Run TR6 & gap them anywhere between 0.038 to 0.042 (depending on size of shot). These plugs are a step colder than stock and help prevent pre-ignition.
Higher octane fuels are a plus, like 93 or higher, but I would recommend to stay under 100.
Good luck.
