Nitrous Outlet switch panel question
Old Jan 15, 2013 | 12:39 AM
Wicked 94TA's Avatar
Default Nitrous Outlet switch panel question
The Nitrous Outlet has a switch panel that mounts in the center console and has a nitrous pressure gauge. Does anybody know if it is a mechanical or electric gauge?
Old Jan 15, 2013 | 05:19 AM
PONTIAC SLP's Avatar
I don't know about the gauge if it's mech or electrical , But you can see , The mecha nitrous psi gauge run a hose from the gauge to the bottle with adapters , The electric gauge Has a harness for the sender psi .
Or if you don't have the gauge , post a link here for the gauge and it will be easy to tell u
Old Jan 15, 2013 | 05:24 AM
I just checked the switch panel with gauge , It's mech gauge
http://www.nitrousoutlet.com/catalog...1&product=2138
Old Jan 15, 2013 | 08:55 AM
Neal@NitrousOutlet's Avatar
It is mechanical
Old Jan 15, 2013 | 03:16 PM
Is it ok to run a nitrous line through the car from the bottle to the gauge?
Old Jan 15, 2013 | 04:38 PM
Chris@NitroDaves
Guest
Posts: n/a
Some people have done it but it's not the recommended way to go about it. it can be done and works though.....
You will need a 4an manifold - 3an Hose - and 1/8th Fem x 3an Male fitting for the back of gauge and 1/8th x 3an fitting for manifold.
Old Jan 15, 2013 | 05:07 PM
Cool, thanks for the info, I'll just make sure to get it all hooked up good and tight to make sure I don't end up with a scene like the cop car scene in Black Sheep!
Old Jan 15, 2013 | 08:08 PM
Chopstix's Avatar
but it's not the recommended way to go about it. .
??? whats the diff. in doing this and running the main feed line or mounting the bottle in the cabin.
