102mm Nitrous Plate
102mm Nitrous Plate
looking to buy a 102mm plate, single or dual stage, looking for recommendations and best prices. currently running a 150 shot, untill the stock block goes then plan on 200-250 shot
Ls1tech & Truck Sponsor
We have a plate for the 102mm that i think would be perfect for you. It is a dual stage plate that is able to spray up to 400hp per stage and comes complete to so so on a single stage.
Give me a call and we can go over the details and make sure that we get everything that you are wanting.
Trey
Trey
We have both single and dual stage plates.
Single
http://nitrousoutlet.com/catalog/pro...7&product=4111
Dual
yea, the motor seems very healthy and made great power, dont expect to blow it up anytime soon (knock knock) just going for a cleaner install, but @ $320 im kind of leaning toward a direct port set-up
oh yeah definitely. Direct port would be awesome. If you can do it yourself you can save on the labor. Usually a direct port system will run a pretty good amount more than $320.
