175 shot on 93 pushing it?.
Old Jan 19, 2013 | 06:51 PM
PaSteLaSo4U's Avatar
Default 175 shot on 93 pushing it?.
Just wondering if 150 would be the highest you guys recommend with 93 pump? (given the car is tuned fine and whatnot)
Right now I'm at 125 but if wanted to go to a 175, can i run with 93? If not, can i just throw some race fuel in the mix? I heard the standalone tank it's the way to go for anything bigger than a 150, but wouldn't mixing race fuel in the gas tank do the same? Only benefit i can think of to have the dedicated tank is, you only use it when you need it and don't have to "waste" the race fuel if you aren't going to race...
Old Jan 20, 2013 | 12:59 AM
Detoxx03's Avatar
I did it for a few months and didn't have any issues. I eventually went to a standalone cause I decided to go with direct port and obviously a bigger shot.
Old Jan 20, 2013 | 10:57 AM
baezi z06's Avatar
i ran 200 many runs on 93 , just matter of right plugs and save timing
i used br 8 plugs gapped .033
good luck
Baezi
Old Jan 20, 2013 | 10:54 PM
BOOSTEDcatfish's Avatar
id say as long as ur turners good and u read plugs u should be good.
make sure your pressure doesn't drop through out the gear
Old Jan 20, 2013 | 10:55 PM
boostit5.3's Avatar
im running a 200 shot on 93 with br7 plugs gapped .035, this is on a 5.3 though. 23 degrees of timing
Old Jan 20, 2013 | 11:09 PM
what fuel system?
Old Jan 20, 2013 | 11:28 PM
boostit5.3's Avatar
its a Granatelli 255 fuel pump on stock fuel lines. in the future im thinking about a 100 dry shot and running a 250 single wet nozzle on a stand alone fuel setup.
Old Jan 21, 2013 | 11:45 AM
Neal@NitrousOutlet's Avatar
You should be ok as long as everything else is in check. The right plugs (br7ef) if you are still stock compression, enough fuel pump (255 with hot wire is good for 600-650WHP) and enough timing pulled (start with at least 8).
From there you can work on tuning it back in for more power.
