need help with window switch
Old Jan 22, 2013 | 06:44 PM
WS600461's Avatar
Default need help with window switch
i havent been able to get my window switch to work right yet what i have is a zex wet kit with the black box and a nos 15982nos window switch can anybody give me a diagram or advice on how to wire this thing up i suck at wiring.ive found some diagrams but none with my exact kit trying to get this done before the weekend...
Old Jan 22, 2013 | 11:14 PM
03EBZ06's Avatar
Page 3 has a nice graphic of how to:
http://www.holley.com/data/Products/...R10482rev4.pdf
Old Jan 29, 2013 | 07:07 AM
WS600461's Avatar
Got my kit wired and it halfway works i tested it with the nozzle out thank god but I have it set to spray at 1300 on 1700 off just to make sure it's working and it sprays but if I take it to say 2000 Rpms when it comes back thru the window it sprays again. Also if I take my car to redline and look at my tps voltage and rpm it says I turned my car 6900 Rpms when my tach says 6000 but my rpms on the switch are correct if I just slowly rev it out any ideas what my problem is
Old Jan 29, 2013 | 09:47 AM
Neal@NitrousOutlet's Avatar
so does it start spraying again at 2000??
You might need to relearn your TPS on the window switch.
Old Jan 29, 2013 | 10:04 AM
WS600461's Avatar
Yeah it will spray the window i set but it also sprays again with the Rpms comin back down in the window also so it would spray say 4000 to 6000 and I shift at 6200 then when I slow back down it would spray 6000 till 4000 potentially blowing my engine
Old Jan 29, 2013 | 10:29 AM
Chopstix's Avatar
the issue is with your WoT detection or lack of....the switch is activating off RPM only
double check all wiring connections...tps voltage/micro switch...and the settings used in the window switch
Old Jan 29, 2013 | 10:32 AM
WS600461's Avatar
I'll double check all wiring again tonight any idea why the Rpms are so much diffrent at wot I know my car isn't revving that high
Old Jan 30, 2013 | 01:15 AM
03EBZ06's Avatar
FYI:
On my NOS MINI, if using the tach output from PCM, it had to be set in 4 CYL mode to indicate the correct RPM. If attached to a coil ground, I believe its set to 1.
Old Jan 30, 2013 | 09:09 AM
What chopstix said. Sounds like a programing problem on the TPS. Check and report what you have set on it.
Old Jan 30, 2013 | 09:19 AM
WS600461's Avatar
Took my bottle out and weighed it I think that's my problem I only had maybe 4 pounds in it I reprogrammed my kit and it working now once I fill my bottle I'll update this thread and let y'all know how it runs
Old Jan 30, 2013 | 12:56 PM
Chopstix's Avatar
sounds good...hope everything goes as planned for you
the nice thing about that style of controller, it will show you the signal output changes on the display for testing and verification
Old Jan 30, 2013 | 01:11 PM
WS600461's Avatar
I think what was going on was the tps voltage was off on the controller once I got it where I needed it works like a charm. Tps voltage a wot is 4.6 so i set it at 4.4 is that correct?
Old Jan 30, 2013 | 04:27 PM
yup thats correct
Old Feb 6, 2013 | 11:04 AM
WS600461's Avatar
Got the kit working sprayed two times before I broke 3rd gear damm t56. Bottle pressure on the first spray was around 900psi and I was like 125hp shot my *** felt like 30hp so I drove around some and got the psi up and it hit alot better at 950psi till 3rd blew is 1000psi to high? What should my pressure be at for best results
