MSD Window Switch may be dead....:((((
Old Apr 17, 2004 | 04:25 PM
BillyRay's Avatar
Unhappy MSD Window Switch may be dead....:((((
I finally got my nitrous system done the other day and I was out trying it out. Well the thing won't spray...
I tried several things and the problem is I'm not getting power to my soleniods. At first all my tests included the Window Switch in the setup......well today I decided to just bypass the Window Switch and just run a ground to that particular post on my relay.....AND THE SUCKER WORKED!!!!!!
So I rigged it back up with my Window Switch in place and now I'm not getting power to my solenoids...
This MSD switch is brand new!!!!! I mean it's been on the car a few months while I have been slowly getting my nitrous install done, but this was the first time I had tried to spray...
Is this common??? I had never even heard of a story of a bad switch???
Jesse
Old Apr 17, 2004 | 05:25 PM
aram's Avatar
Jesse
Everytime I had a problem with a window switch it was because I hooked it up incorrectly. Make sure the tach signal wire is working first.. I usually try a shift light or tach hooked up to it just to make sure I have the correct wire. Also remember that the window switch should really only be used to ground out a very small current (like that of the switching part of a relay (86-85)) so if you try to make it ground out something that pulls a lot of current (like to the solenoids or something) it won't work. Also make sure you cut both wires for 4 cyl mode because the LS1 tach signal is not like a standard v8 one.
Also I have heard that sometimes the MSD window switches need to be modified to work with gm coil pack ignitions, but I've never had a problem with any.
Old Apr 17, 2004 | 06:28 PM
BillyRay's Avatar
Yeah I have cut the 2 small wires to put it in 4 cylinde mode. I have it wired just like it says in the TNT install instructions.
I know for sure I have the correct tach wire since I have my shift light tapped into the same wire.
Old Apr 18, 2004 | 05:17 PM
mikey94_95's Avatar
BillyRay,
I sent you a PM!
