Newbie Question - - 150 shot ok?
Old Aug 9, 2002 | 08:21 AM
unit213's Avatar
Administrator
Default Newbie Question - - 150 shot ok?
Can I run a 150 shot on an internally stock motor? From everything I've read, I should be ok.
I have a friend who is going to install a kit for me for $200. He owns a shop so it's no big deal to him. I'd give some details, but unfortunately I don't know anything about nitrous yet. I'm just getting into the game. I do know however that it's not NAWWWZZZZ....damn, i hate that movie!
Dan
Old Aug 9, 2002 | 08:35 AM
2000 Camaro SS's Avatar
Default Re: Newbie Question - - 150 shot ok?
I would go slow first try a 75 shot then a 100 or 125 shot. If you want to be safe you will need to add a inline fuel pump for the 150 shot. Some people have done a 150 with out any extra fuel pump at all but they risk detonation and other troubles. I will put it this way my kit goes to 150 I have owned it for three years and have never done a 150 yet. This weekend I will finish up my fuel pump install and then I will shoot 150. Another thought is will you be able to hook up with a 150? I can't with a 100 and 28' slicks.
Old Aug 9, 2002 | 09:55 AM
unit213's Avatar
Administrator
I didn't know that the stock fuel pump wouldn't be able to supply enough fuel. As far as traction, I'm sure I wouldn't be able to get any since I'm on GSC-s right now. I'll be upgrading to 17" nittos soon. That should help some, but if you can't hook on 28" slicks... <img border="0" title="" alt="[Sad]" src="gr_sad.gif" /> .
Can a 150 shot kit be installed and only spray 75?
Since I'll be getting it so cheap, I feel I'd be stupid not to get the 150 kit. I can always upgrade whatever I need at a later date.
I know that it's most beneficial to spray right out of the hole, but since I won't be able to hook can I spray mid track?
BTW, my buddy owns a Motorsports shop so he could do anykind of tuning that's necessary.
Thanks for your help. I need all the feedback I can get here since my nitrous knowledge is very limited.
Old Aug 9, 2002 | 10:20 AM
Some feel it is safe with stock pump but the guys that have been around awhile will say no. Your kit (150 HP) will most likely have different jets that will allow you to set different HP shots. What kit you getting?
My kit does 50, 75, 100, 150 shots your will do something like this also. There are different ways with the traction problem. I was shooting 100 HP shot off the line with 5500 RPM dumps. I need to set my nitrous to come on slowly with a progressive controller or come off the line at a lower RPM. I use a window switch to turn on my nitrous. I put pills in like 3300 RPM to turn it on and 6300 for off. I also use a WOT (wide open throttle switch) So my car has to be up to 3300 RPM AND I have to have it floored to work. This is important if you have a 6 speed. With out one when you try to shift you will still be shooting nitrous and over rev and blow your motor. If you shoot at less than 3000 rpm's and you have to high of head pressure and maybe BOOM. I also use a fuel preesure safty switch so if my fuel pressure drops below a certain point it stops the nitrous from going. This would be bad if it did not.
Heck some people don't spray until second gear so this way they know their hooked up.
<small>[ August 09, 2002, 10:35 AM: Message edited by: 2000 Camaro SS ]</small>
Old Aug 9, 2002 | 11:06 AM
unit213's Avatar
Administrator
I'm not sure what kit it would be. I'll talk to my friend to get some details. He had this same kit set up on his '01 C5.
