Building a custom stand-alone(Help)
Old Feb 5, 2013 | 04:01 AM
lilmiller74's Avatar
Default Building a custom stand-alone(Help)
I am building a custom stand-alone for my c6 to look somewhat like this one.I am running a 150 shot now on the stock bottom end off of the rail but im thinking of jumping up to a 200 shot with an hsw 90mm plate and running c16 in the stand alone. Any info or advice is appreciated.
http://forums.corvetteforum.com/c6-p...el-system.html
I need some help figuring out what fuel pump and FPR I should use.
Here are the parts i had in mind.
Fuel pump, this one is preset to 13.5 psi.
http://www.jegs.com/i/JEGS+Performan...15915/10002/-1
Or can I use this one which is preset to 6.5 psi.
http://www.jegs.com/i/JEGS+Performan...15913/10002/-1
This is the FPR I plan on running.
http://www.jegs.com/i/JEGS-Performan...15909/10002/-1
Also one last thing, with these pumps being low pressure am I going to have to run the carb sized fuel jet.
Old Feb 6, 2013 | 01:38 AM
So far this is my progress. I will be picking up the pump and regulator next week.
Old Feb 6, 2013 | 02:20 PM
Juicedh22's Avatar
why such a low PSI pump? Why not just go to auto zone and get an external fuel pump for some car? I used to use the mid-90s Ford Ranger pump, and make my own -an fittings to adapt to it. you can regulate up to 55+psi.... Pump is like 70 bucks... (this was for custom race car fuel system, not a standalone n2o system)
Old Feb 6, 2013 | 05:34 PM
From what I've read the low pressure pump makes it easier to tune and make adjustments.
Old Feb 7, 2013 | 11:43 PM
Can I get some help or any info from anyone?
Old Feb 11, 2013 | 08:56 AM
Bump for some help
Old Feb 11, 2013 | 02:10 PM
Z284U2TRY's Avatar
You will need to use the carb jetting if going with a low psi set up.
I would use the first pump with a 13.5 standard psi for more adjustability on the fuel side.
You can use the 6.5 psi pump but make sure you use the correct jetting.
jegs and holly have reg/pump combos
Old Feb 11, 2013 | 11:51 PM
Ok that is what i was thinking about the jetting, Thanks for the info!
Old Feb 12, 2013 | 12:15 AM
1badeagle's Avatar
I would use potato
