Please help with quick question before I make Transaction!
Old Feb 16, 2013 | 04:09 PM
LASTOFTHEBREED02T/A's Avatar
Exclamation Please help with quick question before I make Transaction!
Im currently maxed out on injectors 28.8 for any type of dry shot. If i go wet instead, do i still need bigger injectors? or can i stay with the ones i currently have? I installed a Racetronix fuel pump, to help out with the demand.
Please let me know, and sorry if its a stupid question. Just trying to save cash if i can get away with not buying injectors.
Old Feb 16, 2013 | 04:23 PM
Sofls1's Avatar
When you say maxed out does that mean 100 & up duty cycle?
A wet kit does not use the injectors for the additional fuel, it does pull the additional fuel from the rail but uses a fuel jet to add the fuel.
You should be fine, but everyone's setup is different so I cannot tell you for sure that your in the clear without more details, but a racetronix pump can supply a lot of fuel and is probably up to the task.
Old Feb 16, 2013 | 04:36 PM
No im not at 100%, but for any type of Dry hit i will be (PreMaf). Maf is already close to maxing also so it wouldnt be able to compensate for extra fuel as well. Given that a wet shot will not pull or make the injectors work any harder, and feeds off the fuel rail. its safe to say with timing pulled, i should be ok, right? Keep in mind i already have a good fuel pump installed.
Old Feb 16, 2013 | 04:43 PM
Sofls1's Avatar
I'd say you're probably good with a wet kit.
Old Feb 16, 2013 | 05:12 PM
I appreciate the reply and help... Wet kit it is!
Old Feb 16, 2013 | 05:30 PM
Killer5.3's Avatar
Our injectors are at 104% duty cycle on motor and we run Nitrous Outlet Wet plate. Our duty cycle actually drops to about 80% on a spray pass.
Old Feb 16, 2013 | 05:33 PM
Thx, and gd info... but does that apply only to certain set ups? Im going with a dual fogger.
Old Feb 16, 2013 | 06:28 PM
Justins00ss's Avatar
I run a dual fogger with the racetronix pump and hot wire kit with the 28lb injectors with no problem. 150 wet kit.
Old Feb 16, 2013 | 07:35 PM
Killer5.3's Avatar
I was just showing that the wet kit provides all the fuel you need either pulling off the rail or a standalone and that the injectors dont matter as long as they are adequate for the motor or n/a needs. Our car is cam only and we plan on injector upgrade when we do heads. It shouldnt matter what kind of wet kit you go with just make sure your pump can keep up . I would get with whatever vendor you purchased the kit from on their recommendations for fuel as far as pump size and whether you need a standalone.
Old Feb 17, 2013 | 02:39 AM
Thanks killer5.3, and stand alone would b nice
Old Feb 17, 2013 | 02:42 AM
Nice man... this clears up alot of questions. What do you make NA? Im at 427rwhp, I want to do a 150 shot but dont know if my motor can take it. May just stick with 125 shot
Old Feb 17, 2013 | 09:10 AM
stroked383HSR's Avatar
LOL!!!...im keepin my eye on you my brotha!
good luck with the wet hit!
Old Feb 17, 2013 | 09:32 AM
Made about 365 through a th350 and a 4200 stall. My original motor took 150hit for 100k miles plus before spinning a bearing. As long as the tune up is good then you should be OK
Old Feb 17, 2013 | 09:43 AM
Stalker!!!.... thx bro.
Old Feb 17, 2013 | 10:54 AM
Thanks for info... ill be sure to have the right timing pulled.
Old Feb 19, 2013 | 10:57 AM
TeEnAgE pHeNoM's Avatar
You won't have any problems on a 150 with the correct spark plug, timing pulled, and nitrous jetting. I also think you'll be fine with the injectors even if they are at a slightly higher duty cycle then wanted. When you shoot a wet kit it decreases the load of the maf so naturally the idc will drop.
Old Feb 19, 2013 | 04:55 PM
T AM's Avatar
What rod bolts were you using?
Old Feb 20, 2013 | 06:13 AM
Stock rod bolts and head bolts. Have another motor going together now with arp head bolts and rod bolts
Old Feb 20, 2013 | 09:49 AM
Thank you sir for this great info... As far as spark plugs, I'll be installing some NGK BR7's, and 8* of timing pulled even if i run on a 125 or 150 shot. I know 125 is more timing pulled than necessary, but I'll be on a fixed time puller that cant be adjusted on a dime.
Should i need a TC window switch if i go with a ZEX TPS box? Similar function is it not?
