VP Q16 racing fuel
has any one used this fuel
it´s hard to get racefuel here in Iceland but i can get a barrel of VP Q16
Q16 will work well in any drag racing application -- naturally aspirated, nitrous or blowers. Q16 is highly oxygenated, requiring a 4-6% increase in fuel flow, which will make 3-5% more power than competitive 116 octane fuels. Q16's oxygenation will significantly expand the range of air/fuel ratio acceptability, so performance will be more consistent and won't vary as dramatically with altitude or density changes. For bracket racers, variations in ET from run to run will be substantially reduced. This added fuel flow also effectively increases its octane by 6-8 numbers above its standard ASTM octane rating.
http://www.vpracingfuels.com/vp-drag-racing.html
i´m thinking of it for my standalone fuel cell
Baezi
Q16 work very good for boosted cars.
Nitrous brings its own oxygen it doesnt need an oxygenated fuel to help it.
Made the tune up more sensitive, not what you want.
Debating on what to buy for my standalone. Stuck with 91oct here in Nebraska.
C16 is 17.74 per gallon here.
I got jets from Neal for 200-100 n2o size and close corresponding jets for low pressure standalone and C16. I'm guessing AFR will still be targeted around 11:5 WOT on the spray the spray
It will work fine for smaller shots but like I said it makes the tune ups more sensitive.
There is a reason NO ONE that sprays alot of nitrous uses it. If it made more power or worked better they would and we would have stuck with it if it did.
We didnt just try it once, we used it for about 1/2 a season.
