Just bought a kit...methanol injection?
...I decided to buy a wet kit off another member on here. I have two questions.1. We only have 91 octane around here. Could I use a methanol/water injection system, at WOT only, of course? Do people do that?
2. Should I get an actual nitrous tune, or will I be good with a timing controller? I do have an innovate wideband gauge hooked up.
Thanks!
Thanks!
Just use a timing controller. Its easy and effective. Make sure you use colder plugs and that your fuel system is up to the task. Leave the wideband off and tune by looking at your plugs when you make a pass at the strip. Only use the wide band as a reference after you get the tune right on the plugs.
Get the LNC 2000 from Lingenfelter it will pull the timing and is easy to install and use. It will let you run motor timing all the time and only pull timing when you spray. Make sure you have a hotwire setup on that pump so it will get all the voltage it needs. TR6 is a bad idea, that is a projected tip plug, you want non-projected. You will need to run a br7ef (3346) as for the plugs.
By the way I just read your first post again. Forced induction such as a turbo system doesn't cost 15 grand.
Thanks for the advice, everyone.
Just like you are adding a nitrous kit to your car. You could of got someone to fab up a hotside for you, bought a $100.00 CX racing intercooler 3 inch piping from jegs, and some silicone couplers and you would be maybe a lil more than a grand in. Get a t76 from Rob@modular turbo for ~750 bucks. There are a couple of odds and ends and you would want to get a boost friendly cam. You will initially have spent more, but guess what? No refills! While you have that setup on the car you can save for the big dog set up.
Plus you can't spray your way faster than what a forced induction setup will do. You can take a stock LS1 car and just put a turbo kit on it and it will run 10's. You can't take a stock LS1 car and just put spray on it and run 10's.
