Which Ngk plug to run on nitrous .
Old Mar 6, 2013 | 09:29 PM
Seulatr97's Avatar
Default Which Ngk plug to run on nitrous .
Ls1 stroked to 383 made 530whp adding a 200 shot of nos. should I run a 7 temp or 6 an what should I cap it at. Nos want be sprayed much mainly all motor. So i need a plug that's works for that. Plz people that only deal with nos cars reply plz. Thanks
Old Mar 6, 2013 | 10:19 PM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
I would recommend a br7ef for a 200 Hp shot and it will still be a plug that you can daily drive without any problems. Also I would gap them to around .32-.35.
Trey
Old Mar 7, 2013 | 12:03 AM
Detoxx03's Avatar
BR7EF's are good. I ran the 8's in mine.
Old Mar 7, 2013 | 08:16 AM
Carter01's Avatar
If your motor made 530 rwhp and you are adding a 200 rwhp shot we are talking about over 700 rwhp on a ls1. I would run at least a #8, MINIMUM!
Honestly, for my liking it would have a #9 in it. There is more than one way to skin a cat but i prefer the safest way. You can't daily drive on 8s or 9s however without tune adjustment.
Old Mar 7, 2013 | 12:51 PM
Seulatr97's Avatar
So I could run the 8s if my tuner can get the tune right or should I just crab the 7s an just change the plugs when I get to the track.
Old Mar 7, 2013 | 01:36 PM
5.0 LsX's Avatar
my car didnt daily drive too well with the 7's, maby in the tune i dont know... if you are going to change them at the track anyway i would just get the 8's for track and maby 6's for dd
Old Mar 7, 2013 | 03:42 PM
Carter01's Avatar
If you don't mind swapping the plugs just run the 8s when you get to the track. Even at 500 plus rwhp NA I would be on nothing hotter than a 6 NA.
Old Mar 7, 2013 | 10:28 PM
Detoxx03's Avatar
**** I ran around town on 9's before. It's all in the tune buddy.
Old Mar 8, 2013 | 10:39 AM
Neal@NitrousOutlet's Avatar
whats compression?? I wouldn't be in 7s. You are going to need 8s
Old Mar 8, 2013 | 11:06 AM
boostit5.3's Avatar
if it was a stock motor on a 200 you should be running a 7 or 8. on your motor with a 200 shot you should prolly look into a 9, although a br8ef would prolly be a great middle ground imo.
Old Mar 8, 2013 | 11:07 AM
boostit5.3's Avatar
and im spraying a 200 shot on a 5.3 and my gaps are .30 never had an issue with spark.
Old Mar 8, 2013 | 06:37 PM
Seulatr97's Avatar
I believe my compression should be a 10:5:1 but not sure I've got to figure it out I've got .51 gaskets on none shaved patriot heads.
Old Mar 9, 2013 | 04:40 AM
Dynospeed's Avatar
Have you been running a smaller shot already? What plug did you have the best luck with then? If you just put nitrous on start smaller and work your way up. I would suggest a 7 up to 175 shot and a 8 when you get to a 200. Also keep the timing low and work your way up. What fuel are you running?
Old Mar 9, 2013 | 05:23 AM
ssman00's Avatar
My car is a 383 with 12:1 compression spraying a 200 shot running br7ef ngk
