What way to mount nitrous bottle
Old Mar 14, 2013 | 10:59 AM
GiggleJuiced_SS's Avatar
Default What way to mount nitrous bottle
is there a certain way this needs to be mounted for the best performance? i have mine where the t tops would go in the hatch. the top of the bottle is facing the driver side rear quarter panel.
Old Mar 14, 2013 | 11:08 AM
mikh338's Avatar
im pretty sure it needs to be a 15* angle or more with the valve pointed up
Old Mar 14, 2013 | 11:21 AM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
With almost every bottle out there the valve needs to be facing towards the front of the car and the nitrous feed line needs to be pointing down. Also it does need to be mounted at around a 15 degree angle for optimum performance but if it is more it will still work just you may not get full performance with a low bottle due to the nitrous being force to the back of the car.
Trey
Old Mar 14, 2013 | 10:40 PM
Ok so i think ill move it. Any good deals on a trans tunnel mount? Also i need to upgrade my solenoids and lines to go up to a 250hp shot. I already have a nitrous kit but its only good to a 150.
Old Mar 21, 2013 | 08:46 PM
egod's Avatar
most people talk about a bottle warmer, but make sure the bottle doesn't get too hot. You wanna try to keep it out of the sun, if that nitrous makes it to 97F it stops becoming liquid and becomes vapor. This means its less dense and will not be set up properly for your tune. You want to make sure its liquid, but has enough pressure.
Old Mar 24, 2013 | 11:44 AM
i have a gauge and bottle heater kit that is pressure regulated.
