lt1 nitrous questions
Old Mar 17, 2013 | 07:59 PM
englundjd's Avatar
Default lt1 nitrous questions
ive never messed with nitrous before but im looking at getting a dry kit, and progressing to a 150 shot.
my question is, should I get a plate kit or a kit that injects the nitrous infront of the MAF?
it seems like that 2nd choice would be easier to setup and tune
Old Mar 17, 2013 | 10:21 PM
Chopstix's Avatar
LT1s do not use "through the MAF" dry systems...the PCM wil not add the extra fuel reliably
LT1 dry kits use the nitrous flow to force the fuel pressure regulator to increase fuel pressure which in turn forces more fuel through the injector when it opens for its normal duty cycle.
I would suggest not running a dry kit on the LTx platform...go wet and call it a day
Old Mar 17, 2013 | 11:48 PM
1slow96z's Avatar
i would def. suggest a nice wet kit on an lt1 aswell
Old Mar 18, 2013 | 04:26 PM
joeZ96's Avatar
I agree. I never had very good results with a dry kit. I then converted to a TNT wet plate setup, and whoa buddy. I'm now running a Nitrous Outlet plate.
Old Mar 19, 2013 | 06:55 PM
englundjd's Avatar
alright thanks guys ill look for a wet kit.... how did you guys pull in the fuel for the wet kit? just tap the shrader valve or splice a tee into the fuel lines?
Old Mar 19, 2013 | 07:01 PM
1slow96z's Avatar
i went right off the schrader on the back of the rail
englundjd's Avatar
how come dry kits dont work very well? does the maf max out when it sprays or does the computer just not adjust fast enough?
Old Mar 19, 2013 | 11:19 PM
MEAN LT1's Avatar
Not reliably.
Old Mar 22, 2013 | 01:44 PM
englundjd's Avatar
Originally Posted by MEAN LT1
Not reliably.
thanks
Old Mar 22, 2013 | 09:56 PM
Chopstix's Avatar
Correct...its not reliable to use the MAF/PCM calcultions to provide proper fueling. This is why every company that offers a dry kit for the LTx plarform does not use the MAF/PCM to provide fueling.
Why are you wanting to use a dry kit on that particular application?
Old Mar 22, 2013 | 10:20 PM
ls13ater's Avatar
You need to run a wet kit my car has a 2 stage maf kit, 150 on first stage 150 on the second
