Spark plug reading
Old Mar 19, 2013 | 04:04 PM
getsum27's Avatar
Default Spark plug reading
tell me what you think
150hp
.062 and .033 jets
93 octane pump gas
Old Mar 19, 2013 | 04:12 PM
shortdog's Avatar
9 Second Club/Nitrous Mod
Rich
Did you pull any timing? Can't really see the timing mark.
Old Mar 19, 2013 | 04:29 PM
getsum27's Avatar
heres a better pic
getsum27's Avatar
23 degrees timing on this pass
Old Mar 19, 2013 | 04:53 PM
03supercobra's Avatar
Good plug pics, are you doing this at the track? I would pull another degree to be on the safe side and lean it out a bit, see how the fuel ring and timing mark are, and then maybe add the degree back in from there. If your at the track, see if it picks up with the changes. Do you have a wideband by chance?
Old Mar 19, 2013 | 04:59 PM
camscam02's Avatar
Go to a .031 and pull a degree, see what it does from there. Probably need a .030
Old Mar 19, 2013 | 05:15 PM
Neal@NitrousOutlet's Avatar
You are not idling any are you?? You shut it down after the run right correct.
From the pictures you are a little rich. Timing needs to come out. This would be if there wasn't any idle time on them.
Old Mar 19, 2013 | 05:33 PM
getsum27's Avatar
Explain to me about the timing.
The timing mark is so close to the end of the strap I thought that was extremely safe.
I've always been told get the timing mark close to the curve
I cut the engine off at the stripes.........
Old Mar 19, 2013 | 05:39 PM
getsum27's Avatar
double post
Old Mar 19, 2013 | 05:43 PM
camscam02's Avatar
"on the bend(curve)" is a general saying that has been adopted over the years. The fact is that "on the bend" might not be optimal for everyone. The only real way to find where your combination wants the timing mark (to me) is to get the fuel correct while having low timing in the motor (low timing will only hinder performance, not hurt parts) and then start adding timing 1 degree at a time until your et starts to fall. When it falls pull it back 1 degree and see where the mark is on the plug.
There are always different ways to do things and for sure this could take a good amount of passes but we intend to aim on the safe side for all things.
Finally the reason everyone is telling you to take a degree out is because when you lean a motor out automatically your putting more heat in the motor so taking that extra degree out as you lean it down will ensure a little more window of safety and like I said, you can always add it back in. Make small changes and let the timeslip and plug tell you what the motor wants.
Hope that helps!
Old Mar 20, 2013 | 06:04 PM
dekan513's Avatar
not to take over the post but, whats the best way to find the sweet spot for fuel other then a wideband.
like what am i lookin for on the porcelain .
Old Mar 21, 2013 | 07:37 AM
ATVracr's Avatar
Cut the plugs ... want an 1/8th inch thick or less ring around bottom of the porcelin.
Old Mar 21, 2013 | 09:04 AM
dekan513's Avatar
ty much, thats what i was wanting to know.
