Nitrous install help ASAP
Can someone please tell me which wires to tap into for installing the TPS switch and the MSD window switch? I am installing a NX wet kit on my 2000 SS. Also, if anyone has any good pics of their install to give me helpful ideas on the wire routing and placement for ease of install please send.
Thanks,
Scott
purevilss@aol.com
Thanks,
Scott
purevilss@aol.com
Looks like it's the #24 wire, dark blue on the red C2 connector.
Here's where I got it from: http://www.ls1.com/2002pcm.htm
Oops...gave you the 2002 link by mistake. Here's the one for 2000 models. Looks like it's the same wire. http://www.ls1.com/00pinpcm.htm
The #10 white wire is the tach wire on my '99, and probably the same on your 2000. Maybe you're confusing the TPS wire with the tach wire
