E85 tune and nitrous
Old Mar 21, 2013 | 06:26 PM
BigAlex's Avatar
Default E85 tune and nitrous
My 2000 z28 is currently tuned to run ethanol, was wondering if I could safely shoot a 75 wet shot without getting it retuned and how much timing would I have to pull on a 150 shot?
Car is stock besides tune and full exhaust, what gains should I expect to see?
Old Mar 21, 2013 | 07:56 PM
egod's Avatar
you should still be safe with a 75 shot. Are you running any type of programmer/controller? because of the lower A/F needed I would make sure you run in richer or pull timing with the 150 shot.
Old Mar 21, 2013 | 10:47 PM
blackonblacksls's Avatar
I sprayed 100 on my motor tune on e85 in my ls7.
With a tr6 and alot of compression
Old Mar 22, 2013 | 12:24 AM
BigAlex's Avatar
So 75 should be safe? Even though my current e85 tune probably push timing forward?
No programmer or anything else, just an HP tune from a local performance shop. Don't want my ls1 going boom
Old Mar 22, 2013 | 12:25 AM
BigAlex's Avatar
You had an e85 tune prior to going nitrous like myself?
Old Mar 22, 2013 | 04:05 PM
Yes e85 motor. Hooked up a 100shot nossle on a button.
After tuning the car on motor, hit the button whenever I wanted for 100 extra hp.
Same plugs same tune same fue.
I hear alot of others are more cautious. I'm just telling you what worked for me.
Old Mar 24, 2013 | 02:07 AM
BigAlex's Avatar
At 170k I think I might pull some timing just in case, might go for 150 shot anyways just to get my money's worth on the tune
