Carter01 SBE Nitrous Update.....
@ Steve - Man this is a street car, but i can't drive all the way to Commerce! lol...
You do not hit a radial soft! You PLANT that mug in the track, use compression in the shock to hold it there and do NOT pull power from the moment the trans brake releases so that it drives through the converter coupling transition to lock up smoothly. Once weight is transferred if the nose drops when the converter couples it will take the tire off.
Or work boots, Nick and I will put you to work! haha
I don't mind doing work son! lol...
