Need Help ... Which/What Bells & Whistles
Old Sep 17, 2002 | 07:42 PM
TXNC5's Avatar
Default Need Help ... Which/What Bells & Whistles
On a 6sp, what do I need to be safer? Is a TPS enough? Do I need the RPM window switch? Do I use both?
I did buy the NX 75-150 kit, but I did not order a TPS switch. Need some help asap as the install is soon.
Thanks.
Old Sep 17, 2002 | 07:46 PM
Country Boy's Avatar
Senior Member
Default Re: Need Help ... Which/What Bells & Whistles
To be safe...
Window switch, WOT switch, fuel pressure safety switch..
I think thats it.
Old Sep 17, 2002 | 10:24 PM
TXNC5's Avatar
Just to make sure, WOT switch being the same as a Throttle Position Sensor switch?
Old Sep 18, 2002 | 06:53 AM
Bad02WS6's Avatar
Yes. A WOT switch does the same as NX TPS.
WOT means, Wide Open Throtle.
You have to have a window switch. < It is a must for 6spd.
You could get a fuel pressure safty switch, or a rich-lean safty switch.
You also need a bottle heater. It is very important to keep your pressure consistant. If its to low, you will run rich. If it's to high, you will run lean.
Old Sep 18, 2002 | 09:40 AM
ls1290's Avatar
Dumb Ass Vette Moderator
Blow down tube, blow off valve, and a nitrous pressure gauge if you are going to run the bottle heater. Also, it is not a bad idea to have a fire extinguisher in the car too <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Sep 18, 2002 | 11:33 AM
F.A.T. PERFORMANCE 01's Avatar
you definetly need a window switch becuase if you over rev the engine without a window switch you have no way to stop the nitrous from spraying a tps switch is a great idea and a gen-x kit from nx is also a great idea i have a 98 trans am that has a nx 75-150 kit with 15 lb bottle w/heater fuel cut off switch tps switch and rocker panel swithces it is very safe i run a a4 so idont need a window switch you will ne very happy with that kit i went 11.74 at 118 mph this weekend on nittos with no motor work if you have any questions feel free to ask i installed my kit
Old Sep 18, 2002 | 01:54 PM
TXNC5's Avatar
Thanks for the responses. I did get the kit with blow down, heater, purge, and automatic opener. Just trying to find out the "other" items needed. Ordered the TPS switch yesterday, and I guess I'll get the RPM and fuel pressure switches ordered today.
If I run all three of these swtiches, do they all connect to the same circuit? Or do they turn off the nitrous through different circuits? Is there a hi-level wiring diagram anywhere?
Thanks.
Old Sep 18, 2002 | 04:36 PM
Senior Member
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by TXNC5:
<strong>Thanks for the responses. I did get the kit with blow down, heater, purge, and automatic opener. Just trying to find out the "other" items needed. Ordered the TPS switch yesterday, and I guess I'll get the RPM and fuel pressure switches ordered today.
Thanks.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">This is the TNT kit, so you get the point <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
<img src="http://www.imagestation.com/picture/sraid29/p8605c2fe855e3ba95f3dad6cb2ef266b/fd5c4a39.jpg" alt=" - " />
Old Sep 20, 2002 | 12:22 AM
TXNC5's Avatar
Thanks Country Boy
