Heat + Solenoid = Bad?
Old Sep 18, 2002 | 03:50 PM
justin sutton's Avatar
Default Re: Heat + Solenoid = Bad?
I have had mine mounted on the front of the intake for about 3 months no problem here.
Old Sep 18, 2002 | 09:41 PM
Ed Blown Vert's Avatar
I am just wondering if moving them away would be better for them?
Old Sep 19, 2002 | 12:03 AM
Im really not shure.I just know where mine rae and I have had no problems.
Old Sep 19, 2002 | 12:12 AM
Default Heat + Solenoid = Bad?
How much heat can the solenoids take?
I was wondering because mine are mounted on the intake.
And I already had to send mine back for a leaky seal.
Old Sep 19, 2002 | 02:40 PM
Chris Spiess's Avatar
When you say already, how much use are you talking about? Do you keep nitrous in your lines even when you're not using the N2O? Seals are a wear item and eventually have to be replaced. Performance wise you the closer the solenoid is to the jet the better.
<small>[ September 19, 2002, 02:44 PM: Message edited by: Chris Spiess ]</small>
Old Sep 19, 2002 | 04:47 PM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Chris Spiess:
<strong>When you say already, how much use are you talking about? Do you keep nitrous in your lines even when you're not using the N2O? Seals are a wear item and eventually have to be replaced. Performance wise you the closer the solenoid is to the jet the better.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Brand new solenoid. About a bottle through it.
NX said it was probably a bad seal from the manufacturer. So heat was probably not the issue, but made me wonder. My solenoids get really hot. So I was thinking about relocating them to the firewall and off the engine.
At night I do purge the lines.
<small>[ September 19, 2002, 04:48 PM: Message edited by: Ed LS1 Vert ]</small>
Old Sep 19, 2002 | 04:50 PM
Just remember the further away the solenoids are from the nozzle the softer the hit.
Old Sep 20, 2002 | 10:51 AM
Thanks. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Sep 20, 2002 | 11:21 AM
realtech9er's Avatar
My solinoids are 2ft. away from the fogger! Is that close, or should I go closer...It works fine for me though! How close is yours?
