Dedicated fuel systems for nitrous using race fuel
Old Mar 30, 2013 | 11:52 AM
Trackman's Avatar
Default Dedicated fuel systems for nitrous using race fuel
I have just started my research to add nitrous to my ZL1. I am considering a dedicated fuel system as my current fuel system is nearly maxed out with my current mods.
I have a bunch of questions!
Does anyone build a stealthy tank set up for the 5th gen Camaro?
If I run race fuel for say a 100 shot will I need to back off timing?
I suspect most race fuel is leaded. Will that have any negative effect on sensors? Any comments regarding nitrous and supercharged applications would be appreciated.
Old Mar 31, 2013 | 08:42 AM
Dynospeed's Avatar
On the ctsv's we put the stand alone in the trunk. On a v making 710whp with a 100 shot on top it made 868whp and we pull 2 degrees at peak tq running c116 in the cell. I would start pulling a couple more like we originally did then work up from there.
Old Apr 4, 2013 | 06:24 PM
Trackman's Avatar
This is exactly what I am looking for. I am also wanting to do direct port injection as well
What fuel are you using for the engine? 94? If so how do you tune for the two different burn rates of two different fuels?
My builder is suggesting we do a dry system with no fuel cell but he wants me to run C16 all the time but that is not practical as I have an hour drive to the track. I do not trailer it.
Old Apr 5, 2013 | 03:50 PM
Nitro Dave's Nitrous Outlet's Avatar
Our 2 Gallon Universal Dedicated is real popular for what you are needing. Its really your best option.
http://nitrousoutlet.com/index.php/f...el-system.html
Dave
Old Apr 6, 2013 | 06:20 AM
Footlead's Avatar
They sell unleaded race fuel but its not 116. You can put unleaded 109 in the standalone and it works great. You don't have to pull any timing on a 100 shot if your running the high octane fuel in your standalone. You can pull 2 degrees out for peace of mind but will lose some power. I have done this on a dyno and on a 125 shot lost 14 hp pulling 2 degrees out but it was clean and no detonation with ZERO timing pulled out. Start spraying more and the equation changes.
Put 93 in the big tank and 109 unleaded in the standalone and let it eat. No cat problems or o2 sensor problems or emission problems.
Old Apr 7, 2013 | 08:31 PM
Dynospeed's Avatar
We run c116 in the fuel cell and since its such a small % of the total fuel in the motor we have never seen a problem. Think about it, you are adding 700 hp of pump gas and 100 worth of leaded for maybe 10 seconds at a time.
Old Apr 8, 2013 | 09:39 AM
Trackman's Avatar
My builders recommendation is to go dry through the blower. We will try his way but make provisions in the set up for wet as well. It should be a cleaner set up , just a pain to switch fuels at the track.
Old Apr 8, 2013 | 10:07 AM
You can go wet or dry. We spray wet systems through the blower all the time. I feel its actually easier to tune using a factory pcm. Unless you are tuning with the EFI live Custom operating system.
Either way is doable.
Dave
Old Apr 8, 2013 | 06:11 PM
Trackman's Avatar
Yes we will be using EFI Live.
Old Apr 9, 2013 | 11:38 AM
Ok, Cool. As long as EFI live offers the COS for your year going that route would be a great option.
Dave
